Question for those who are using E85
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
Do you use an upper cylinder lube?
if so which one and why. I tested 3, Trans fluid, ethanol compatible 2 cycle oil and Power Plus 19769-18 Fuel Additive Alcohol Top Lube.
Trans fluid looked like a water mix and some solids fell out of suspension so don't use it. Both the 2 cycle oil and the power plus stayed mixed. 2 cycle oil is a lot cheaper than the power plus.
I put the power plus in the last tank 2 oz to a full tank and my injectors have quieted down. Haven't tried the 2 cycle oil and wonder how much I should use.
Thoughts?
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
Puddintane
'17 S550
Thoughts?
The 15% of gas is the lubrication. On Ford flex fuel vehicles, Ford says at every oil change run a tank of straight gas.
cbrtrx
tampa fl
2016 mustang gt
Klotz uplon lube is the best you can get in my opinion.
Grimreaper
Dallas
2017 GT
What wildhorse said. Ran e85 for a year straight with maybe one or two tanks of e10. Zero issues.
That's interesting you noticed a drop in injector noise though. I'll have to pay attention when I jump back to e85 from pump.
I pull a fuel sample from the tank to make sure my stoich is set right in the tune. A 100ml graduated cylinder makes measuring pretty easy. The plunger on the syringe I use does not move smoothly with pump gas but on e85 its almost like its lubed.
