Question About Tires
Ashiq73
Southern California
2016 Mustang GT 6 Speed Magnetic Metallic
So, I might be picking up some GT350 Rims soon (Non R).
I know the OEM Tire sizes are 295/35/19 and 305/35/19.
But the tires that I want and am researching do not come in those sizes.
They do come in 295/30/19 and 305/30/19.
Would there be much difference between the two sizes?
I am assuming just the tire profile would be slightly smaller.
The tires I am considering are Bridgestone Pole Position S-04.
Thanks
angermgmt14
Massachusetts
2016 GT Premium--Oxford White--A6
You will just have a thinner sidewall and more wheel gap. Speedometer may be off a tad too.
awmustang
Milwaukee, WI
2017 EcoBoost Premium PP
This will tell you exactly how big of a difference it will be and how far off your speedo will be. Put in the size your car came with and these new sizes.
http://www.1010tires.com/Tools/Tire-Size-Calculator
If your car had a square setup and these are significantly different from each other in overall diameter the stability and traction control might throw errors since it will be seeing the front and rear moving at different speeds.
Shouldhavegotthegt
Phoenix
2016 Magnetic GT 2014 Ram 1500 RCSB 4x4
Roads are terrible in SoCal. Stick with a 35 or 40.
Need4SpeedMotors
Los Angeles, CA
www.n4sm.com
N4SM Team
Thanks
Keep the factory tires from the 350 setup those are MPSS tires, well worth to use them and then switch.
