Pulleying down
Section,al
Richard
2018 mustang gt procharged
2018 procharged gt premium . Thinking about dropping pulley size . Running 3.70 now on p1sc-1 making 6.5 lbs want to get to 9lbs . Does anyone know the increase ratio .
Thanks in advance
ProChargerTECH
Boostville
2015 Mustang(s)
Sounds like its an HO kit with shared 6 rib? If so you will need at least a 3.50" and a few more RPM to get there. I personally don't like going smaller than that, due to the possibility of belt slip due to the 6 rib
18stormtroopergt
Section,al
Richard
What would it cost to swap everything to 8 rib . Do they make a kit for that .
Jackson1320
California
Jaxson
2015 mustang gt
What would it cost to swap dre to 8 rib . Do they make a kit for thĂżat .
you can run a overdrive balancer to get more boost without belt slip. you can convert to a 8rib. i have converted mine to 8rib. i can give you a parts list if you need. it's about $1000-$1500 depending on a few things.
ProChargerTECH
Boostville
2015 Mustang(s)
You can either do the full conversion to the 8 rib (dedicated drive) which is pretty pricy... Or just run an overdrive balancer for now which will net you a larger crank pulley and a bit more boost (fairly cheaper alternative).
18stormtroopergt
Section,al
Richard
Searched for overdrive balancer with no luck by any chance do you have a link for that
Jackson1320
California
Jaxson
2015 mustang gt
