Procharger intercooler leaking from the MAF
Dominant1
Dr Frankenstang
2016 gt/cs auto 3:55 gears
Get some gasket material and make your own. Use a little permatex to insure a good seal..
my66coyote
Illinois
1966 Mustang , 2008 Lexus ISF
I just had the same issue a couple weeks back. Made a pressure tester, found the it leaking pretty significantly from the sensor. Used some black rtv and it seems to be holding fine. I searched high and low for that stupid little square gasket separate, same results as you.
whatsup62
Jupiter
When I went to the GT350 charge tube, PC sends a plug to put in place of where the MAF was in the IC. I had a leak on the plug. 5 min epoxy did its thing.
JPSTANG
MN
Joe
2017 Mustang GT
This, all day long... fixed mine as well, just make sure you dont get gasket maker on the maf itself
Jay-rod427
Kansas
2016 GT C/S
That is not meant to be a water tight fit. The ever so tiny amount of air that can get out is like .0002% of the volume flowing. That is not a “boost leak”.
ProChargerTECH
Boostville
2015 Mustang(s)
This....
There is zero reasons to spend any time trying to "seal" that.
As long as your bolts are snug and the sensor doesn't fall out, you are good.
(even if it did, its hardly enough of a hole to cause much of a boost loss, however you'd have bigger issues cause the car wouldn't run)
