Procharger D series
Jak112460
AZ
2015 Mustang GT
It varies greatly from machine to machine. General consensus is usually about 6-10% higher on a Dynojet but that's not set in stone.
Ok. I read somewhere else that it was about 12% but I was hoping for some people who had real world experience with this. My car is an automatic also.
PowerAdderGT
Mustang
Lots of things to consider, what rpm did you taken it to? What gear did you dyno in? Was it SAE, STD, or uncorrected? What was the elevation of the dyno?
z06psi
Evans, GA.
Andrew
The pot stirrer
D1SC (4.5" pulley) + 13 psi + CAT deletes + 3" Catback + 7700 rpm = 702 rwhp on a dynojet.
Dyno at sea level and it was 83 degrees
foghat
Calgary
2015 GT w/PP
On my 135i I dynoed 406/460 on a dynojet. Right after drove to a dyno dynamics dyno and put down 357/403.
Hard to do a direct comparison, but I believe Mustangs and Dyno Dynamics are pretty close in terms of numbers.
Hoblick
Ohio
2015 Mustang GT PP
D1SC, on the HO kit, long tubes, full exhaust no cats, 12PSI @ 7200 RPM, 14 degrees of total timing, 631RWHP on 93
Sinister
Missouri City, TX
2015 Black GT PP
Which pulley?
amotorsports
TAMPA,FL
2015 PROCHARGED BLACK GT PREMIUIM
I have a D1 with 15psi putting down right at 700. Youtube- coastal dyno truck muffler assassin. That's on the mustang dyno. Its a very good combo....
Burnin4
Mooresville
17 GT350
Rob, clean out your inbox.
PowerAdderGT
Mustang
I see your running a waste gated set up, how do you like it? 699/599 are very good numbers. :
What pulley are you on? What's the waste gate set to?
amotorsports
TAMPA,FL
K like it a lot with the small pulley. Boost comes in faster and gained more torque. I also have a innovative boost controller on it. Very nice setup...
PowerAdderGT
Mustang
What pulley, what lb spring, and whats your controller settings?
