ProCharger D-1X is in
donmcgowen
Chicago
2015 Mustang GT, D1 Procharger Stage 2
What rpms are you shifting at to see 10psi? [MENTION=6362]TommyV[/MENTION] is making 15 on the 4.75 by like 7500. You read that right. 15psi. FYI I have a brand new 4.38 for a D1. Pm me if you are interested.
Shifting about 7500 rpm. How much psi you hitting with the 4.38? How much you want for it?
foff667
Clermont, FL
2014 Mustang GT Procharged D1X
Have you seen anyone else running this blower? It is hard to believe the fuel system is tapped out unless this thing is pumping out the boost. Have you had a boost gauge on it yet?
I would have to agree with this, with DW1000 injectors you shouldn't be close to running out of fuel unless your fuel pump is on its last leg or something odd.
In any event did the new fuel system end up fixing your issues? What is your IDC at @6500 & @7500 rpm?
Dominant1
Dr Frankenstang
2016 gt/cs auto 3:55 gears
I'm running this blower with the stock pulley and id 1050x injectors and a vortech bap. I'm right at 13lbs of boost making 723 rwhp. No fuel starving issues here but i do intend to go e-85 at some point. My tuner is finishing up r&d on flex fuel tunes for boosted cars & when that's completed i will pull the trigger. Right now my only issue is traction, the ground is just to cold for my dr’s!
Tommy V
Brookly park Md
Tommy
That 4.38 would be perfect if u put a Watergate on your car.
Terminated
Terminated
GTFO_0009
MA
Marcus
Bagged & Boosted 50th Anniversary
Tested my OE pump and it was weaker than normal. Fuel system fixed the issues and the car is much stronger up top now since I can put power in it. Ended up being a good idea on the system as I plan to switch to ID1300s
foff667
Clermont, FL
If you don't mind how did you test it?
Atticaz
Arizona
2017 Mustang V6
