Procharger belt size?
Mbutler183
Highlands Ranch, CO
Mitch
2018 Ford Mustang GT
Currently on a p1x ho kit 3.75 pulley, swapping to a 3.25 pulley. Is there a calculator anywhere to determine what belt size I'll need?
silverbullet85
San Diego
2019 Gt
I would call procharger and ask tech
LSchicago
Illinois
Lloyd
2018 Mustang GT/A 301A 5.0
Don't know HO kit sizes, but Procharger will be able to help you out. Will be roughly an inch smaller than the one you have now or so.
Mbutler183
Mbutler183
Highlands Ranch, CO
Mitch
Yeah, looks like I'll need to figure it out. Emailed procharger twice and called, no response. PM'd procharger on here, no response. That was before creating this thread
TRP45ACP
Houston, TX
2018 GT Premium Coupe, PP1, MT82, 401A
If you call procharger during business hours, ask for tech. They will transfer and you should be able to get the belt part number needed. I have done it three times as I have pulleyed down my car. No issue.
Keo_S550
Missouri
Daniel
2017 S550 GT Premium Ignot Silver
Ive asked them the same question and they will suggest that you should go to a stage 2 bracket system rather than pulley down that far. I’m currently on a 3.4 making around 15lbs and my tuner suggests I don’t go over 16 because that’s where most of the issues of valve float or lifting the head begins. I can tell you tho that I have thought about doing that. But it’s more effective to look at other things engine wise to get more power than just a simple pulley swap. Ported intake? Weight reduction? Headers? MAK inlet? Stuff like that
Jackson1320
California
Jaxson
2015 mustang gt
You don’t need to pulley down you should get a overdrive balancer. I have a 20% overdrive balancer and a 3.7 pulley. Planning on a 3.5 soon. I have ran more than 16psi without issue on a stock Coyote. I’ve never heard of valve float issues with a centrifugal supercharged coyote just turbos. What causes the float?
Keo_S550
Missouri
Daniel
Im glad you have had no issues running over 16lbs on a stock motor, but just because you have doesn’t make it a good idea. I just follow what my tuner tells me to do or not to do. If they say shit starts messing up over 16lb then I believe them.
Jackson1320
California
Jaxson
2015 mustang gt
I understand that. I’m just saying that I personally had no problems at over 16psi. What valve float issue comes with 16psi on a centrifugal?
Mach1soldier
Cocoa Fl
Luke
2021 Mach 1, 2020 f150 EB
3.75 x 3.14. =11.77
3.25 x 3.14. =10.20
so basically a 1.5 inch shorter belt
mangosmoothie
Flagstaff
Casey
2019 Boolet
3.75 x 3.14. =11.77
3.25 x 3.14. =10.20
There isn't 100% belt wrap. More like 50%. so probably a .75" shorter belt.
Mach1soldier
Cocoa Fl
Luke
That’s a good point.
LSchicago
Illinois
Lloyd
It's actually closer to 70% around, so about a inch. Belts are not available in all lengths, but usually go down about an inch at a time.
