- Banned
- #316
No sensible contribution? Deflection? Come on man. Don't be ridiculous. Your fantasy land argument is based on paper. Mine is based in reality. You get no PMs when you speak so ignorantly publicly.
Still more deflection and personal attacks... who would've guessed. You seem to be getting really emotional about this
Facts are the motor in the GT has a lower output than the motor in the GT350, the weight differences are negligible, the gearing is somewhat negligible. There's no disputing that.
So, if it's so negligible, then how come the GT ran near dead even with the GT350 at a rolling start on the back straight of VIR? Reality is that there isn't nearly as much of an acceleration difference as you think there is
So what does Ford do to make the GT appear fast on paper? Put some wide track compound on that thing and give it some of the suspension goodies from the Shelby.
Wider stickier tires don't just make it faster on paper, it makes it faster in real life. Look at 1LE vs PP1... PP2 has about all the same upgrades as the 1LE has. Tell me, do you think the PP2 will run anywhere near the times that the 1LE runs, or did Ford just spend thousands developing a failure of a car?
And, for you, that now means - again on paper - that oh the PP2 is as fast or faster than a stock GT350. It's foolish of you to be sold so easily.
On paper is literally ALL that we have right now, and again, you're saying that ON PAPER the GT350 is significantly faster, so you can stop calling the kettle black now.
The GT350 doesn't have cup2s because the R does. Anyone going to a track to seriously flex their vehicle - whatever vehicle that is - is going to use tires suited to the event. That's common sense. Your refusal to embrace it doesn't make your argument stronger - it just makes your bias more apparent.
Correct, and remind me, what else does the R have over the standard 350 that makes it so significantly faster? Some wheels and mild aero work. Again, Tires are most of the gap there. and okay, sure, some people may swap tires to go to the track. But that's not we're discussing. We're discussing whether the showroom version of the PP2 will be faster than the showroom version of the GT350. Having to bring up modifying a vehicle to give it the advantage... That is the true show of bias. talk about being in a fantasy land
I'm simply asking you to use common sense and stop drinking the marketing kool-aid if you're actually trying to make an intelligent argument about which car is truly faster. And I'm simply asking that you really look at the facts and embrace that, yes, with the PP2 having no speed disadvantage, less shifting, the same suspension minus hubs and rear LCAs, same suspension tuning, but STICKIER tires, it COULD be faster.
^^This guy gets itTires can make a noticeable difference. Look at Camaro SS vs 1LE, C7 GS vs Stingray, etc. Yes, there is more than just tire at play (other suspension mods) but the same is true of PP2. Ford's own internal testing shows a substantial improvement on a tight technical track.
