Fastfwd
I'm not sure I'm going to do this, but I would like to at least know about it in the event I ever decided to. I'm considering running the stock wheels as a 'winter' set and the possibility of picking up a set of aftermarket wheels that may be a much lighter set for the stock summer only tires I took off the car when new. The theory being that those heavy stock wheels may be more durable and better suited for winter driving and I don't care about blowing $100 twice a year to mount summer only/all season tires. You could spend $200+ a year doing that if you wanted to run the sticky tires and risk your wheels each time in the process of mounting them. Plus, I would much rather just roll out the floor jack and swap my own summer tires on whenever I feel like it. Now that I feel like I've justified it in my mind for the rest of the world.....
I'm curious if there is any reason for concern of making sure the offset of the aftermarket wheels is within certain parameters? I honestly just don't know enough about this topic to make an informed decision and I primarily don't want to introduce an imbalance to however the car is setup from the factory with all of the high tech stability management, traction control, etc.
I'm not talking about anything extreme, but it might be nice to add a touch of depth to the rear wheels if a little less offset can achieve that without upsetting the balance of the setup. The factory wheels really downplay the staggered wheels/tires and I might like to see a subtle hint that those rears are a bit larger.
Also, I'm sure this depends highly on the specific wheel in question, but I'm curious how well lighter wheels fair on these S550 Mustangs? I guess I'm thinking the Mustang might be a bit heavier than some cars certain wheels might be more geared toward. Anything to specifically avoid? From Tirerack I sort of like these Enkeis http://enkei.com/shop/tuning/raijin/ To me, they look a lot like the PP2 wheels. Probably easier to clean. Not sure how well Japanese wheels would be accepted on an American car, but they look pretty stock to me and they are super light by comparison - 10lbs less each. Not quite as wide as stock though. Otherwise, Tirerack has these American Racing wheels https://www.americanracing.com/wheel/44835/ar927-barrage They just don't look any easier to clean. In fact, they might be worse and I'm not sure about those spokes protruding from the lip of the rim from a curb rash standpoint.
Thanks!
Thanks!
