PP Wheel Rubbing
ansibe
Toronto
2016 GT PP, Recaros, Koni Yellow, 350r springs.
No, it's not a fetish ...
I have two sets of PP wheels, and I planned to run a square setup at the track, rear wheels on both axles, 19x9.5 with 285/35.
But, mounting the rear wheels on the front causes minor rubbing between the wheel and my Koni yellows. Static clearance is very tight, maybe 2mm. Turning the steering wheel 1/4 turn causes rubbing. Rear wheel offset is 52.5mm, and you need a bit more to be comfortable. I may use camber bolts to get the wheel away from the strut, and camber plates to get the neg camber I want.
maddawg57
Winchester Va.
2015 Comp Orange Premium PP GT
Yes to run the 9.5s on the front you need a 5 mm spacer
Paul@PKAUTODESIGN
The Wheel guy
Los Angeles, California
WWW.PKAutoDesign.com
Paul A.
2016 Shelby GT350 Tech Pack #G5531 Avalanche Grey
Use a 5 mm spacer it will solve it for you, you need it for the strut clearance.
ansibe
Toronto
Thanks.
Can you get hub centric 5mm spacers? If not, how do you center the wheel?
NightmareMoon
2016 Mustang GT PP w/ Voodoo
