FMJ
Cheers for the reply.
I get your other points however.
If you mount the cooler so it can drain with gravity it will be empty at some point. So next time the thermostat opens won’t there be a period of time that the oil system has all the air from the empty cooler pushed through it? Meaning a lack of oil until the cooler and pipes fill and the air vents into the block?
As I said I’m no expert so may be getting it wrong.
The RHD cooler is clearly crap. The way it works should be fine as loads of cars use that method.... unfortunately Fords cooler design perhaps coupled with its location is not up to the job. I just don’t want to swap a potential failure point for a DIY solution that may be another failure point. Hence trying to understand it all.
If you look at the pic of the block with the manifold attached you can see the engine mount bolts pass through it. Hence the RHD mount sits about a inch off the block which is taken up by the manifold. If you were to remove the manifold as some people have in OZ you would need the US engine mount which goes straight on the block. Otherwise the mount wouldn’t touch the block on its bottom bolts. Or you could cut the oil manifold to turn it effectively into a spacer for the mount to block. But this would be permanent. Hopefully that makes sense.the engine mount is uneffected by the silly oil manifold we have.
