Xavier
My IATs creep up to 30-40* above ambient if I've been driving around in traffic for a while. Granted, it gets hot here in GA but it does make me concerned for the temps when I'm waiting between runs at the track.
Thanks! Yes that's right, The IAT always reads higher as you said, even stock.Yes it's read at the MAF but just know it reads 5-6* high. Dead cold start in the morning after car sitting 12 hours or more shows the following. Ambient air temp 78* IAT 84* CHT 90*. CHT might be off too it seems it never matches ambient either.
I can't hear mine over my headers anyway :lol:Thanks! Yes that's right, The IAT always reads higher as you said, even stock.
Last night I drove around town at 50 mph, then at 75 for a couple of miles on the hwy. At 85 deg, the IAT was 91-93. Not bad. I did an experiment and let the car sit idling for 5 minutes. The temp rose to 120. After a couple of miles back on the road it was back to the 6-8 above. I have a foam block on top of the intake tube covering the void where the tube is cradled. I also have 10 holes open in the grill on the intake side. Still haven't opened the PMAS box up any more. I have noticed the temps drop quicker after idling when I have this piece inserted. It drops the intake roar a bit too, which is good or bad depending on what you like to hear.
Put clay or silly putty on top of your foam seal and see how close it is to sealing.I'm going to try and put in a piece of painted Lexan instead of the foam to act as a partition, and find a similar rubber gasket like is found on the unit to seal against the hood. I could secure the Lexan with a couple of screws that can be taken out to remove the piece when needed. I think it would look a lot better. The foam does insulate well but I don't have it perfectly sealed yet. Modeling clay or a similar thing would be good I think, to help find the right height. Lay a bead of it and close the hood to see if and how much it deforms.
As someone else already pointed out, the IAT always reads higher than the car's thermometer. I checked it first thing this morning when I started the car up in the garage. It started out at 6 degrees above, so we are not doing too bad. :cheers:
Yeah mine is instantly 5-6* higher than ambient the second it reads. Even my HP Tuners scanner reads 5-6* higher.You need to be real quick when starting but on my UK car, ambient this morning was 9c, plugged in SCT and IAT also 9c. Started car and got to the gauge IAT cluster as quick as I could within 1s of starting and for a millsecond it was 9c, by a second later it was 10c.
So on the UK cars the IAT is not above ambient, just looks that way if you wait a few seconds before checking gauges after starting.
Since my IAT modifications, I can report highway 50-75mph stays 2degrees above ambient, city/traffic holds 4-6degrees above and stop lights or traffic jams and it holds within 10degrees.
Before I did my modifications the IAT was vastly more higher than ambient. The only downside of my modifications if bugs, spotted at least a couple of dead flies, so need to take a hoover to the filter every month.![]()
