Piston Slap after not starting in a while? 3rd Gen Coyote
Mustang Tony
Los Angeles
Tony
'18 Mustang GT 10R80 PP1 401A Magneride
Hi All,
I never usually get this, however only one other time where I haven't started the engine in long time....like 3 to 4 weeks....let's say 4 weeks. However, when I started up I was getting the clack, clack, clack sound. This is NOT the typewriter tick.
It went away after several minutes (3 to 5 min.) when it got warmed up. Is this piston slap? Is it normal? (Car has 9,800 miles)
Thanks!
Skye
≈39N
"Skye" Mach1 N2144
MY22 here. I have not heard any such noises after being off for an extended period, then starting.
AZlb5.0
Arizona
Carlos
18 GT Premium
When you let the car sit for too long all the oil drains to the pan and out of the pump. leaving very small amount of oil film on the cylinder walls. If you start the engine it’s going to take a second for the pump to prime and start distributing oil.
This has occurred with GTOs as wel when sitting for a long timel. What we do to circumvent the slap is before starting the car we press the gas and clutch pedal at the same time and it causes a crank no start. We do it for 15-20sec which primes the pump and gets the oil flowing.
See if that works next time it should stop the piston slap. It has been proven to stop te piston slap on GTOs.
BigBeed
South Jersey
2019 GT Premium 401a PP2
For peace of mind after the car sits for a while, I'll build up the oil pressure before I start it. To do this, hold the gas pedal to the floor, then press the start button while keeping the pedal down. It'll turn over for about 8 seconds and stop. If the oil pressure hasn't increased, release the gas pedal and do it a second time. I usually do it twice then start it normally, but some people do it 3 times.
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
If it was a clacking sound it is probably a lash adjuster bleeding down.
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
Puddintane
'17 S550
Which is worse than just starting it.
BigBeed
South Jersey
To be clear sitting for a while for me is storing it for 5 months over the winter.
Cold cranking is about 300 or so RPM with no combustion forces being applied anywhere. Firing up the engine results in about a 2000 RPM spike and big combustion forces being directed at various journals and bearing faces, during which not every part of the oil circuit is necessarily at full pressure.
Will either hurt the engine? Not really, but there must be some reason Ford made it so you could build oil pressure without starting. And like I said its more just form my peace of mind.
WildHorse
N/A or GO HOME
Puddintane
'17 S550
Mine as well. I fire it up, let it Idle, done. For 6 years now. No problems.
Holding the pedal down is for when the engine is flooded, doing compression tests, yada, yada.
But like you said, if it gives you peace of mind, it's all good.
