Performance Package Wheel On V6
fordguys550
yep..."just" a V6
tehachapi, ca
2016 v6 6spd
The fronts are very flush. The rears poke about 1/4"...but in only on prokits and havnt touched the camber. There is 0 rubbing though.
fordguys550
yep..."just" a V6
tehachapi, ca
2016 v6 6spd
Heres another
vnzbd
So FL
2016 V6
fordguy, do you feel that running a wider tire affects performance at all? I would expect it to stick better in the corners but how about straight ahead as in a 0-60 sprint?
fordguys550
yep..."just" a V6
tehachapi, ca
2016 v6 6spd
I didnt notice any loss in mpg, or 1/4 times...better actually cause they hook alot better than a stock 235
Need4SpeedMotors
Los Angeles, CA
www.n4sm.com
N4SM Team
IMO the wider the better but with a proper wheel and tire choice, you gain alot width, traction, footprint handeling and breaking. It depends on the wheels you go with .
menq27
menq27
Phoenix
2015 Mustang V6
looks so good bro!!! where did u get em tho?
menq27
menq27
Phoenix
2015 Mustang V6
btw does the Tire pressure gauge works with XXR? what else should I be aware of? I'm new to car mods, thx bud
fordguys550
yep..."just" a V6
tehachapi, ca
2016 v6 6spd
I had my stock sensors installed on them
D12DirtyDozen
LA
V6
Was also thinking about buying GT PP wheels for my V6.
How much heavier are they vs stock? I'll likely be buying 19" wheels anyway, but why such the negative feedback on the Oem?
fordguys550
yep..."just" a V6
tehachapi, ca
2016 v6 6spd
I want to say the combo is like 13 to 15lbs heavier per wheel/tire, assuming you have 17s currently. Im sure the stock 18s are a few lbs heavier per wheel than the 17s
D12DirtyDozen
LA
V6
Are the 19's considered heavier than normal vs other aftermarket 19's? Or are they right on par?
CB
Near Pittsburgh, PA
2016 GT, Black, PP
I don't know why. And many think that the Pirelli tires are junk also. I like the wheels and the tires are great performance tires. You just have to watch when you use the tires. They don't like cold weather. the warmer the better.
fordguys550
yep..."just" a V6
tehachapi, ca
2016 v6 6spd
Similar to regular tips, maybe a little deeper down low.
TheMagneticV6
Virginia
2016 GT Performance Pack premium
So it's just the quad tips? No x-pipe or anything?
