BmacIL
Enginerd
- Sep 21, 2014
- Naperville, IL
- 2015 Guard GT Base, M/T
- Vehicle Showcase
- 1
The only difference between the PP front bar and the base is that the PP bar has what is called 'sticky' bushings, that improve on-center feel. The bar is identical otherwise, so unless you want to go significantly stiffer (Steeda/BMR/Eibach), don't bother with the work to change it, IMO.I called Tasca and there is a PP front stabilizer bar. Part #: FR3Z-5482-B. The non PP version is Part #: FR3Z-5482-A. The mounting bushings however are the same part number implying the diameter of the 2 is the same.
Does anyone know the difference in the two? Is the PP made from a stiffer material? Or is it solid vs hollow? The sales material says when you order a GT with PP you get a bigger rear stabilizer bar. It says nothing about the front however.
I'm sure the aftermarket Steedas etc are much better, but I'm on a budget and would like to see if the stock PP ones make a noticeable difference, especially in the front since it looks a bit more involved to change
Also, is there any way to tell from my VIN what I actually have installed on my GT?
