performance pack pads and rotors
grue
wisconsin
2018 Base GT + PP1
  • Uses Ford Service Part FR3Z-1125-A or Motorcraft BRF1460 Brake pads
  • Uses Ford Serivce Part FR3Z-1125-D or Motorcraft BRRF246 brake rotors
from several sources on the internet, these are the pads and rotors of the 6 piston brembo pads and rotros on the gt performance pack.
now, wonder who makes those pads for motorcraft?
stoli
Fat Guy Racing
Lakeland, FL
'15 Black GT/PP
Brake pads are FR3Z-2001-C.
MustangCollector
NYC
Various vintage shelbys
Pads and rotors are made in italy by brembo, motorcraft/ford reboxes them under their own sku. I had the parts brand new in box sold them last week
grue
wisconsin
2018 Base GT + PP1
thanks both!
so they're brembo pads then. cool to know.
hey, are these the exact same brakes that were on the '13/'14 gt500 then? they look like it.
grue
wisconsin
2018 Base GT + PP1
oh... ok. ultimately i know i should have a set of pads and rotors for track and street. carbotec is said to be able to switch back and fourth on the same rotor, so that's what i ended up with on my last car and it seemed to be ok but i had only done 2 single day events.
Anthony@HTM
SF
GT350 Track Pack
That would be ideal.
Depending on how hard you track you could go Ferodo DS2500 but if your heavy on the brakes they will fade.
tweekdout
Ashburn, VA
2015 GT PP 6m
Do the DS2500's have the same surface area as the factory pads or are they shorter as a first to market option?
Sent from my Nexus 6 using Tapatalk
Budwise
Austin, TX
2015 GT PP
You can get DS2500's that are exactly the same size as OEM now. However if you go to a track that is very hard on brakes I've found that they don't fade but they however do overheat and smear pad material on the rotors and by the end of the weekend your brakes will feel kinda gunky through the pedal and you'll ultimately have to toss the pads and get the rotors turned. For slower tracks DS2500 will be perfectly fine.
zizux
SLC UT
2004 WRX STI Race Car
BTW you can clear up pad build up with a sander, no need to turn them.
I did it all the time when I used 2500's on my STI.
