Paxton sanity/fitment check please
jellyrole
Midwest
2017 Mustang GT
Happy Easter or Happy Sunday fellow Mustang nerds! Looking to get eyes on this Paxton 1200SL install for my 2017 GT before I tighten everything up. Any feedback or suggestions or hey you messed that ups are welcome.
Thanks guys!
https://photos.app.goo.gl/CLk8WJL8L4aAufVA9
eisenhauer01
Walkertown, NC
Kenny
2015 Mustang GT
Looks good, I just did a 2200sl on my 15 over the winter. Make sure your intercooler piping is not touching any of the body.
jellyrole
Midwest
2017 Mustang GT
Thank you. I was able to avoid all body contact. The only thing I'm touch is the ac condenser line from what I can tell. I'm going to go ahead and tighten it all up.
jellyrole
Midwest
2017 Mustang GT
Awesome thanks for that. What did you do about the wiper fluid reservoir? Think about zip tieing it back under more towards the headlight
eisenhauer01
Walkertown, NC
Kenny
2015 Mustang GT
I originally did that. It would have worked fine, but I ended up buying all new silicone boots for all connections and they were a little longer. This gave me a little more room on it's own.
jellyrole
Midwest
2017 Mustang GT
What did you do about the flap on the fan shroud? Can't decide if I should leave it closed, break it off, or prop it open. The radiator hose is blocking it
jellyrole
Midwest
2017 Mustang GT
Did you do an intake for it just a filter on head unit? Not sure if I'm supposed to do the air inlet assembly instructions portion or not
jellyrole
Midwest
2017 Mustang GT
Do you have a good picture of red?
Edit by good I meant close up
I don't have anything plugged into that pcv port on blue.
And what's yellow?
eisenhauer01
Walkertown, NC
Kenny
2015 Mustang GT
I did the catch can and it's hooked up to both valve covers as you can see.
I did the vacuum a little different than most but it worked out really well. I'll try to get a pic in a little bit.
jellyrole
Midwest
2017 Mustang GT
Beefcake told me to ignore the air inlet instructions but that also leaves the double check valve thing in the way. Thank you. Much appreciated. It's so close
eisenhauer01
Walkertown, NC
Kenny
2015 Mustang GT
I put an 18+ intake on my car.
I got rid of the double check valve thing.
Vacuum is supplied as follows:
-Evap for Evap. I purchased the 18+ purge valve, evap line, and pigtail connector for a clean install.
-Vacuum 2 for the brake booster (has a small in-line check valve. Also I'm feeding my vacuum/boost sensor here as you can see.
-PCV for the BOV reference
-Vacuum 1 is blocked off. Note, this is not actually vacuum, its just a pass through tube for the IMRC's on the back of the intake (which I have locked out).
qwiknotch
Southern California
Damon
Kona Blue 2018 Mustang GT,2k GT Vert,
Those filters are a huge restriction, in my experience.. You are better off putting the paxton elbow on it with the stock airbox. . On the dyno, I made more power with the stock airbox.
I also recommend getting tbolts and removing the worm clamps
