P301 and P061A
Sariandan
The lowcountry of SC & GA
Kevin
2022 Mustang EcoBoost
*Edit* I meant to put this in the Issues, Repairs, Warranty, TSB, Recalls forum. Can a @Moderator move it for me?
I haven't opened this one up much yet. Today, I was passing some cars on a two-lane road. As I got past the last one and moved back over, there was a lurch, the car started running rough, and the check engine light was flashing. Since it wasn't a safe place to stop, I continued driving and the light went off and the car returned to normal. When I got it home, everything seemed fine. I checked for codes in Forscan and had the 301 misfire code and a 061A Internal Control Module Torque Performance code.
I have cleared the codes, they haven't come back, and everything seems normal. Is there anything I should be looking at or listening for? I doubt there are issues with a coilpack or plugs yet. There are only 1300 miles on the car. Didn't see any oil leaking the, the oil level is fine and, the dash shows "normal" on oil pressure. Think it was just a hiccup?
SnowFox
Mn
Grabber
2022 GT, 2017 ECOboost, Saleen S351
I can't say what caused it. But plugs new or not can be wonky sometimes. Anything like that I would just swap them out of habbit
Coyote Chase
Don
2010/2018 Mustang
Does your Forscan device have freeze frame ability? This will tell you what the car was doing when the DTC was triggered.
Sariandan
Sariandan
Kevin
Good question. I have no idea.
S1lv3rbull3t
Virginia
Nick
S197 2012 Mustang GT
Maybe some bad gas or small piece of trash got caught in the fuel system?? I’ve had bad gas cause misfiring on my Eco before
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
It's usually caused by a toon. If it is not tuned have the dealer look at it when you take it for the first service.
If it does it again take it in.
Sariandan
Sariandan
Kevin
Could be, though before and after we’re fine. I usually get gas at the same station, every time.
Definitely tuned.
K4fxd
NKY
