tweedbean
- Sep 6, 2016
- Balsall Common, UK
- James
- Two MINI's but looking for a Mustang
Hi all, does anyone run one of these in their Mustang? I haven't seen the onboard digital gauges on a S550 Mustang to know if this shows anything additional to the code reading/clearing.
I always run a scan gauge in each car I own, however this being vent mounts it provides a more elegant solution.
Interested in your thoughts, here is some blurb from their site:
P3 Gauges offer a Multifunction gauge that gives you the information you need while maintaining a clean OEM look.
- Plug and Play install - just plug into your obd2 port and install into dash!
- Reads and clears OBD2 Codes
- OBD2 Data for Coolant Temp, Intake Air Temp, Exhaust Gas Temp, Throttle Plate, Vehicle Speed, RPM, Shift-light, Battery voltage, 0-60 timer
- Peak Recall on all functions
- Boost and Vacuum from OBD2 port
- Optional 80psi analog sensor
- Optional Auto-Dim or Manual Dimmer
- 2 x universal 0-5v linear analog inputs
- Includes digital display, custom OBD2 wire harness and control box.
- Track Pack software upgrade
- Adds Air/Fuel ratio through the OBD2 port
- Adds 0-100/60-130/60-0/100-0 timers
