EXP Jawa
- Jun 9, 2014
- Rochester, NY
- Website
- www.torsen.com
- Rick
- 1999 Cobra Convertible, Electric Green
Well, the .3" is about 7mm. It isn't a huge number, but not so fine that it would require calipers to pick it up. If you put the parts side by side, it would be visible, though maybe not so prominent as to jump out at you. Either way, no big deal. But since you asked, it is the reason that the two parts don't interchange. To make the ring and pinion mesh with a 3.55 gear, you essentially have to do away with the shim on the right side and put a double shim on the left. That might push the gears over far enough to engage, but it would also push the diff splines far enough over that the axle shafts won't seat or engage the snap rings.
