Marvinmadman
If I have a bunch left in the tank I will.You can also try a bottle of octane booster.
A negative .96 is almost a -1, so that is not necessarily bad.That sounds like a fuel issue. The OAR should be able to get to -1 on 91 octane. If you're running 93 and you're at -.96, I think it's the fuel. What brand gas and have you tried another? Does the fuel you're using have a 10% ethanol mixture? I don't know if or how much that impacts it but my guess is it would help. It seems almost all gas stations now use the e10, I think it's cheaper and helps them hit the octane number at a lower cost. That's just a guess though.
Are you seeing negative ignition corrections when this occurs?My knock is at light pedal situations, no where near WOT. Like 15-20% pedal and under 0 psi. If I go WOT the knock goes to 0
I'll have to log it to see. I don't think I was able to display that on the X4
Gotcha! The factory knock strategy is very aggressive and will pull timing very quickly to get everything back under control, especially if your CAT's are above 120F. You're lucky to get any timing advance in that scenario.I'm still on the stock tune lol. I want to monitor my car on the stock tune for a while before I tune it. I'm weird.
[MENTION=27727]Marvinmadman[/MENTION] already said it but I was going to say, that is on the stock tune, would be a different story if it was a pro tune. A -.96 when he's using 93 octane is enough that I'd be concerned. Since the stock tune should be able to get to -1 easily on 91 octane and he's using 93. It would at least have me looking for other gas which I think is the most likely cause.A negative .96 is almost a -1, so that is not necessarily bad.
Negative ignition corrections can and will occur as our ecu's continue to add timing up to a point until it see's knock, then it will begin to lower it until the knock goes away. It's the severity of the knock that is important. This can be determined by monitoring the negative ignition corrections. Anything more than -3 is concerning. A tuner has the ability to modify how the engine deals with knock events. This can be very tolerant or very tight, depending on the tuners strategy.
Now that Summer is upon us, you're more likely to see negative ignition corrections as CAT's increase. You will see these at part throttle and a wot, but again severity is what you need to be concerned with. You can help to mitigate this by adding 1 gallon of e85 to a full tank of 91-93 which will bring regular e10 gas to e15. The ecu can handle this as our cars are rated for up to e15 fuel. You can see this in your stft's, because it will have to add fuel to compensate for the greater amount of ethanol. Honestly, this is a great way to keep knock at bay during the summer month's if you have it available to you.
I've actually used 1 gal of xylene plus 3oz of marvel mystery oil to a tank of gas to increase the octane on my Mazdaspeed before e85 was available in my area. The Sherwin Williams people looked at me kinda funny after my third trip to the store just to buy Xylene though. lol
I know! Crazy right?! That's normal for the factory tune and way too rich in my opinion.You guys see how rich the factory tune is in my stock log? It was down to 9.99 AFR in the higher rpm! The good news is that the ECU was adding up to 5 deg. of timing towards the end of the pull in the upper range of the rpm.
