Matt In The Hat
Hook 'Em
- Jun 3, 2015
- Kansas CIty
- Matt
- 2015 Mustang GT Premium PP
I just performed the first oil change at ~5700 miles the other day. I started it right afterwards to check things out (leaks, pressure, etc) and the pressure was fine, maybe a little on the high side but shortly returned to ~40-45 psi. I took it for a drive around the block a little while later and it seemed unusually high at about ~80 psi briefly hitting 90-ish under throttle. Last night I was driving it and it was around the same under throttle, slowly coming down to around a normal pressure under light throttle/idle.
Now, my question is, is this normal or does it seem a little on the high side. I'm worried that I may have under filled it because I bought 2 5 qt jugs and I put what seemed to be roughly 7.5 qts of 5w20 in it. I checked the dipstick (the best I could with that damn strut tower bar in the way :frusty
and it was within the markings on the stick. I never really paid that close attention to the oil pressure gauge before this change so I really can't tell where it was but I don't think it was ever reading this high, I think I would have noticed. BTW temps here are around low to mid 80's during the times that this occurred, if that helps.
Am I being paranoid or am I good and just make sure to monitor it closely and make sure its not getting over 100?
Thanks guys/gals!
Thanks guys/gals!
