nGuage Instructions from Lund Racing
rio16
MAD_50HH
Bay Area SJ, CA
Rio
2015 Mustang GT Whippled Competition Orange
Here's the steps sent to me by John Lund in loading/flashing/updating the Tuner/N Guage properly.
1. When you put the new firmware on the SD card follow the instructions to update the firmware on the device by going to Diagnostics > Settings > Update from SD card
2. Next is try going to go back to Gauges and it will ask you to select a Model. Select Ford then when it asks for Scan Depth do "Scan all".
How to load a tune onto the nGauge. This can be done one of two ways. I will detail both ways below.
1. Unplug the micro USB card from the bottom of the device and plug it into the mini USB adapter that came in the box with the device. Load the mini USB card into your PC/Mac and open up the "Custom Files" folder on the card. Save the .enc tune file from your email and move it into this folder. Once it has been loaded into the "Custom Files" folder, you can exit the window and re-insert the micro SD card back into the nGauge.
2. This method requires a mini USB cable. Plug one end of the cable into the nGauge and the other end into the computer. The device will boot up and you will get a "Couldn't Connect... Is Key on?" message.
-Select the "X" in the bottom left hand corner to take you to the main screen.
-Select Diagnostics > USB SD
-Now the device will be connected to your computer as a Removable Disc. Open up the Removable Disc folder and go into "Custom Files".
-Save your .enc tune file from your email to your desktop, then drag it into this folder. Once your tune file has been loaded into the "Custom Files" folder, you can exit the window.
Now you are ready to plug the nGauge into the vehicle and flash the tune. This is simple. Plug it in to the vehicle via the OBDII port under the dash. Once it is plugged in and powered on, select "Tuning" and follow the on screen instructions from there to flash the new tune.
rio16
rio16
MAD_50HH
Bay Area SJ, CA
Rio
Cowfy
RI
2015 Mustang GT Premium w/ PP
I just got my nGauge from Beefcake (JLT CAI comes today). My nGauge had Lund's most up to date firmware already loaded.
While playing with the nGauge, I was having difficulty getting any readings for the gauges.
rio16's step 2 was the most important: "2. Next is try going to go back to Gauges and it will ask you to select a Model. Select Ford then when it asks for Scan Depth do "Scan all"."
When you select a model, you can select either OBD, Ford, or GM. Initially I clicked OBD since I wanted to scan through the OBD port, and all of my readings were 0. When I clicked Ford (after going through the menu to "forget" the model), it worked like a charm.
I'll let you guys know if I run into any issues loading the tune, but it seems straightforward from here.
Infamous
President of Honda
2015 Mustang GT w/ PP
How did your experience go with the tune Rio? Smoothly? How does the car feel after?
bew
Phoenix
Black 2015 GT PP
For those of us moving from another vendors canned tune (ProCharger + DiabloSport) to Lund + nGauge, do we need to use the DiabloSport and put our car tune back to stock before reflashing with the new goodies?
I ordered my nGauge from beef last week so it should be here any day! I want to hit the ground running...
beefcake
Bethel
2018 Ford Mustang
I would return to stock, it's not really "necessary", but I personally like to start fresh
I always do a KAM reset too before flashing
it's kind of like clearing your browser cache on your computer
ifly680g
Hebron, IN
Mark
2015 Mustang GT PP
Question, If I get a N gauge with a Lund tune can I return to a stock tune if warranty work is needed? Does a tune void my warranty?
Mark
Socalmustang
California
2015 Ford Mustang GT Premium w/PP Race Red
Question 1: Yes
Question 2: It's been discussed a million times, you will find a ton of threads on this.
rio16
rio16
MAD_50HH
Bay Area SJ, CA
Rio
The Tune from butt dyno feels way alot better... Car is smooth on cruising speed idle and WOT... car feels awesome.. great mod power adder. :cheers:
Question 1: Yes
lol about #2
