ngauge questions
Sunburst
Turtle
SC
2015 Mustang GT, 2000 Mustang (project car)
I'm glad you posted this because I had the same problem yesterday when trying to data log. It said 0 files
beefcake
Bethel
2018 Ford Mustang
it will log til you stop it
16s550
Bay area
2016 GT M6 performance pack, whipple charged
And when I stop it does it save the file? Start again and create a new save?
Also does anyone nguage alternate between one green light and one red light the entire time? Kind of annoying.
Another thing I've noticed is it takes a second or so longer to start sometimes. Nguage says 78% alcohol right now. Is that why?
beefcake
Bethel
2018 Ford Mustang
everytime you start stop, a new log is created, as many as your sd card can hold
16s550
Bay area
Brent Dalton
Sua Sponte
GA
2016 Mustang GT PP
So if you keep scrolling through your gauge screens, you will find the screen that controls your LED lights and can set those values to whatever you want. You can also change the signal/sensor. I'm currently using it as a rpm light starting at 2500rpm's and incrementally increasing by 1000 until the last LED at 7500rpm.
Cranking will be longer with e85 if start up fuel isn't adjusted. I don't remember if our cars have a flex fuel table for that or not so it may not really be able to be adjusted.
16s550
Bay area
Thank you sir! I would definitely like to use it as an rpm light aswell. In the signal/setting part will it have the option thay actually says rpm light? I am at work and will try to do this as soon as I'm off.
