New whipple install
Bbarfoot14
Bbarfoot14
RI
2015 Mustang GT PP
That's correct.
I’m trying to picture the best way of doing this with getting the belt on. I’ll have a friend, but my thinking was to put pressure on the spring tensioner as I route the belt. as I’m holding it, I would have my friend slide the adjustable tensioner up to that 75-80% mark and tighten the Allen bolt to lock that position, then I can release the spring tensioner and ideally it’s sitting about half way thru that range?
Did I get that right?
Bluelightning
Bluelightning
North of Houston, TX
Lightning Blue 2017 GT350, 2019 F-150 4x4 Ecoboost (Daily)
I just put mine on with the adjustable tensioner all the way out, checked to see where it sat, and then adjusted as necessary.
Bbarfoot14
Bbarfoot14
RI
2015 Mustang GT PP
Okay so basically you Locked the adjustable tensioner out to 100% and slipped the belt on with the breaker bar putting pressure on spring tensioner? I imagine that left you with the tightest possible belt, and you just loosened the tensioner and slide it back bit by bit till it’s around the 70-85% mark or looked right? Thanks man appreciate your help!!!
Bluelightning
Bluelightning
I started at the loosest, and adjusted tighter from there, but you've got the general idea.
