Plumbing Help Please
NoVaGT
Northern Virginia
2019 PP1 GT Kona
  • Thread starter
  • Banned
  • #1
I know, I know, this is technically Mustang related. But I'm trying to WASH my Mustang, so maybe some plumbing guru member can help. If you can leave this here for a few hours to get some views, that would be great.
O.k.....change of idea.
We have a "slop sink" with a faucet that has an aerator that un-screws. I think I can screw a garden hose directly to it?
Are they the same size fittings/threads?
ETA; Nevermind, ya'll can't tell me what fitting/threads are on the faucet that's here in front of me. What a stupid thing to ask on an internet forum.
Sorry for the stupid questions, I'll figure this out. Thanks for the ideas.
NoVaGT
NoVaGT
Northern Virginia
2019 PP1 GT Kona
  • Thread starter
  • Banned
  • #3
Thanks, we're almost there.
That wouldn't allow shutting off the water to the 1/2 hose outlet for the 99.97656% of the time it's not in use. But maybe an in-line shut-off valve could be put in-between the 3/8" fitting and the 3/8"-1/2" fitting?
NoVaGT
NoVaGT
Northern Virginia
2019 PP1 GT Kona
  • Thread starter
  • Banned
  • #4
lacanteen
Louisiana: Cajun Country
George
wingnutt
MN, FL, WI, MO, KY, TN, CO, TX, CA, WA, TX again
michael
350R avalanche gray
vanquishvzla
Jacksonville - FL
2015 Mustang GT 50th anniversary
this is what i would do...
I'll add a T with 2 valves... one for the actual sink faucet and another valve to connect to a hose... pretty easy.
there is also some Y valves at home depot. just add one between the main line coming from the wall to the sink hose...
ORRadtech
Atlanta, Georgia
FWIW some sink faucets will accept a garden hose fitting.
If it has an aerator it probably won't but it won't hurt to try.
Dr. Norts
Ontario, Canada
2015 Race Red Mustang GT
Add a T directly in line with the cold water feed that feeds to the sink. Do this 1-1.5 feet above where the copper pipe connects to the sink tap. You can do it higher or lower this just seems like it would be a decent height.
Just cut a section of copper out that is the length of the T minus the total the pipe inserts into the T.
Ex. Stick a piece of copper into the T and mark it. Measure this length and multiply by 2 (for both sides of the T). Then subtract this total from the total length of the T and cut a section of pipe from the cold water feed this length.
Solder a hose spigot 1/4 turn ball valve on the end of this T and then you have a dedicated hose outlet without bothering the sink outlet.
Easy peasy.
