New pads without replacing rotors
MexicanFiestaST
Canton, MI
Ed
2020 Mustang GT
Question for you guys who swap between street and track pads without changing rotors(or just change pads frequently, eg @chedder wrote in one of his replies to another brake thread):
How do you bed in the new pads on the old rotor surface?
Background
In the old days, I would always turn drums when changing shoes, then I would turn rotors when changing pads. But it became nearly impossible to find a shop that would turn either, so I just changed rotors and pads together. I did this on many cars in our household in the past, and I bed them in each brake job. The point is, I always had a new brake surface for the pads.
NOW I have a Mustang GT PP1(6 piston Brembo fronts), owned it since new. I always inspect the pads when I rotate tires, and I think it's nearing time for new pads(looking like 3-4mm left, which I will measure more precisely when I do some work on the car Monday), but the rotors seem plenty thick(I will mic them to be sure on Monday). I can detect no vibration when braking, so I know the rotors are not thin enough to be warped. Assuming I'm correct about rotor thickness, I'm loath to buy new rotors just yet. But I know it may be impossible to find a machine shop that will turn them. That's why I want to know from the guys who often swap/replace pads without changing rotors how do you bed the brakes? Do you prep the rotors somehow? Or do you not touch them at all, just put on the pads and go?
SL8888
Sylvania Ohio
Ray
2019 Ruby Red GT-350 # K1989
I'm no certified mechanic or anything like that, so take this for what it's worth.
I use the factory ford pads for the track days, and swap them out with the Z26 pads
for street use only because of less brake pad dust all over.
I have the pads marked so that I can put them in the same location every time.
(Driver side inner & outer and so on) I'll wipe the rotors down with some brake clean, then install
the pads. Then I bed them in like they are new pads. I also Bleed the brakes at the same time when putting the track pads back on at the same time.
I have not had any pulling or pulsing after changing out the pads.
