New Ngauge Firmware - Version 180
Socalmustang
California
2015 Ford Mustang GT Premium w/PP Race Red
That's correct pump gas is up to e10..So if your seeing 9 ish etc your good. E85 will range as well.
I just rescanned it and I did it under 2008 and newer gas. I did not find the one you specified, just the one I mentioned and another that said alcohol relearn. So does that mean I don't have the FF tune on? I can't even load that tune, even though it shows it under my tune files.
Socalmustang
California
It is in fact alc_pct%. What do you mean you can't load the flex fuel rune?
When I run vehicle info, it shows strategy, vin, then tune.
On the tune, under that section, it just shows this:
201329-Manual-15GT-stockairbox-Normal-v3
It does not show the flex fuel tune.
Choking_Victim
Arizona
Justin
2018 A10 GT PP
That isn't a FF tune...did you pay for FF or request when it was free around xmas?
Socalmustang
California
Yeah I paid it, I got the link and everything. It shows up under load tunes, but it does not let me load any other tunes. If you look at my other post on the FF tune thread, I have it detailed on how my screen reads under load tune.
I'm not sure what I'm doing wrong.
Choking_Victim
Arizona
Justin
2018 A10 GT PP
How many tunes do you have from Lund? How many tunes do you have in your custom tune folder on the SD card that is in the ngauge?
Socalmustang
California
I got two tunes, a regular one, then bought the FF tune in january. Under my custom files tunes, I slid over the FF tune, but when I go to Ngauge, it shows the 3 tunes I posted on the other thread.
I keep clicking on the Flex fuel tune and it just highlights it briefly, then it goes away. It does the same thing for the other 2. The only thing I'm able to do is click the "check" below, then it says Flash this tune, without saying which...and then it loads.
I reloaded the tune again today, in hops it would change on my read info, but it still says the normal.
Choking_Victim
Arizona
Justin
2018 A10 GT PP
I'm posting from my phone so I don't feel like hopping around from thread to thread....let's just try from scratch...humor me...delete all tunes from custom tune folder that is on SD card that is inserted in ngauge. Now from wherever you have all of your tunes saved on your PC, drag and drop just the flex tune to the SD card. This should be the only tune on the card. When you go to flash this should be the only option available. Make sure car is on a trickle if you've been flashing the shit outta it as I'm sure the battery is weak.
Socalmustang
California
I'm posting from my phone so I don't feel like hopping around from thread to thread....let's just try from scratch...humor me...delete all tunes from custom tune folder that is on SD card that is inserted in ngauge. Now from wherever you have all of your tunes saved on your PC, drag and drop just the flex tune to the SD card. This should be the only tune on the card. When you go to flash this should be the only option available. Make sure car is on a trickle if you'vebeen flashing the shit outta it as I'm sure the better is weak.
Should I just drop into the SD card or should I put into the custom files?
Choking_Victim
Arizona
Justin
2018 A10 GT PP
place the flex fuel tune in the custom tune folder. no other tunes. I have like 4 tunes in mine and can select whichever. But let's just try one on yours first, so that we can get the FF loaded.
Socalmustang
California
See that's the thing, I have only have the FF tune in that folder, but it shows 3 when I go to load tunes. It shows flex fuel tune first, the the second it says desc: followed by the normal stock airbox tune(even though I don't have that on the file, then the 3rd one shows a flex fuel tune again but it says invalid size.
Choking_Victim
Arizona
Justin
2018 A10 GT PP
are any other tunes on that card whatsoever?
Socalmustang
California
Nope that's all. So I've been playing with it for awhile now and kind of same result.
When you have a chance, can you go to your car, run vehicle info and see under tune, see if its says flex fuel tune on it or what does it read?
I think that'll help a lot.
