az89gt
- May 11, 2019
- Little Rock, AR
- Jeff
- 2015 GT
Okay, I've read a lot of threads and thought I had it figured out, but apparently not. I made a couple of baseline passes a month ago with the 235 Pirelli's and traction control on - That yielded a 13.32 at 108mph with a 2.1 60' time. I'm in AZ so it's hot as hell, hence the numbers. I picked up a set of 275/40/17 M/T drag radials on 03 Cobra wheels and went back to the track last night. I couldn't get the burnout right, and the car just wouldn't leave the line (like the nannies were all still on).
I owned/raced a 78 Fairmont with a big stroker motor for 12 years, so it isn't a case of being clueless - I've done hundreds of burnouts at the track, and done my fair share of racing, so it appears that I'm just clueless on the new technology.
I put the shifter in S, started the burnout in 1st, and when I used the paddle shifter to get to 2nd, the RPM's immediately dropped to 2,000 and quit spinning the tires. If I bounced it off the rev limiter in 1st, would it have shifted to 2nd by itself and then my paddle shift took it to 3rd instead of the anticipated 2nd? (I forgot to look - The Fairmont was so loud and vibrational that you could do everything just by feel) Should I just put it in S and do the burnout starting in 2nd and leave it there???
The other issue is that it just won't leave hard. First I held the traction button for 5+ seconds to disable it, but it was apparent when I launched the car that it was still in control, yielding another 2.1 60' time and 13.57 at 106mph. There was no spinning at all, so it wasn't a case of blowing the tires off - It just felt dead off the line. The second time, I pulled the plug next to the air box which per my research means all nannies get disabled. On that pass it did exactly the same thing!
So, how can I truly turn everything off so I can make a proper pass???
