Need a tune
66sprint6
Middle TN
2015 Base GT PP
Yeah definitely spring for a Flex tune if available, then like said above, you can run whatever you want or even a mixture and the tune will adapt and make the best of it!
JuRuKi
SoCaL
2016 GT/PP
The best options are Livernois or Lund IMO. You can't go wrong with either one of those.
Top_Notch
IL
2011 GT
Two quick questions I'd like to ask for a newb.
1) If NA and my car is basically stock (axle back is only mod), do I still need to datalog?
2) FF tune...other than a tune is there any change that needs to be made? Injectors? Or just the tune? How much HP can I gain w/E85?
Muff Muff
Corpus Christi/Arlington, TX
Michael
2017 Lightning Blue GT PP
More than likely you won't need to datalog. Hell, you don't even need a tune.
47lb injectors are a good idea when switching to e85.
Synyster06Gates
2016 GT Premium
1. Yes, you always need to datalog. No two cars are the same. Will you be fine without doing it? Probably - but it's not worth the risk.
2. If you're using the stock intake manifold you should be fine with no other mods.
66sprint6
Middle TN
2015 Base GT PP
Datalogging will only help the tuner dial in the base map they send you to make your particular car with whatever mods you have happy.
You do not NEED to do anything at all to run E85 other than the tune itself until you start looking at a better intake manifold or forced induction. You can do full boltons and E85 without issue with the stock injectors and pump.
