mali321
- Feb 14, 2021
- Chicago, IL
- Mir
- 2019 Mustang GT 301A
Hi guys,
I recently got an alignment done after I had to reinstall a rear control arm. What do you guys think of this alignment? Anything here that will give me excessive tire wear?
The rear toe was a little more than I wanted, but reading threads here sounds like it might be right at the max acceptable limit. What about the front toe? It is just slightly out...ideally would have liked it just barely in. Front camber is also off between left and right by almost 0.1.
Would you guys advise I get it done again? I don't know if it was placebo effect but I felt like there was additional resistance at higher speeds (thought I had to stay on the gas more). But on the flip side as time went on my calculated MPG has been going up, so maybe it was just placebo effect.
I will be changing my tires soon in maybe the next 5-10k miles, so if it's minimum additional wear it's not the worst thing.
Thanks for your input guys!
Oh I don't track or drag the car, it's only for spirited road carving type of driving. Thanks!
