N gauge help
rozay
rozay
South Florida, Broward
2015 PQ 5.0 MT
Ok I got it figured out.
I put power down watch volts to 13.0v ON and 12.9v OFF and Wake Thresh I put to 50mv... Now ngauge turns ON when car turns ON and OFF when car turns OFF
ll Lund ngauge 93 oct tune, MAK cat delete+xpipe res+muffler delete (yes it's loud), Reische 170 Thermostat,JLT intake, AMR 19" wheels, CJ Pony springs, Blowfish trans bracket, Steeda trans bushing, AM 1"spacers ll
lsxlol
NC
2015 white gt On3 TT // ID1000s // BAP // Corsa Xt
To get the LED lights to turn on and off go to your gauge setting then hit the left arrow then u can switch all of them how u want them.
Tele5.0
"The Pearl"
2015, PP, GT
Is this the screen that has all of the lights with zeros under them along the top? if so, I have been on this screen many times but all of the lights have 0's under them. There is a calculator looking screen too with CE and BS ...checks and X's and a 1-10 I believe pad but I cant figure out what any of it does. when I see the screen with all of the diff. color lights across the top, I dont see anything indicating that a light would be on. I will mess with it some more tonight but...its got me going.
lsxlol
NC
You can tap the lights underneath of it and set it for your RPMs like the green one on the web set for 4000 in or the one beside it go till 5000 and so on all the way up to 7000 is how I have mine set up to save it tap the bottom left corner and it should say. Sometimes it don't save it the first time so you may have to do it one or two times but eventually will save it hope this helps.
Tele5.0
"The Pearl"
2015, PP, GT
Thanks lsxlol! I will tap around some more tonight and see if I can get this to work. I think I am right on top of it but just not tapping correctly or something.
El_Centenario
5L V8PWR
Apple Valley , CA
David
'15 Mustang GT Triple Yellow
I thought I was the only one getting these issues. I will check my gauge when I get home and adjust as suggested.
rozay
rozay
2015 PQ 5.0 MT
This might help out some
Tele5.0
"The Pearl"
2015, PP, GT
Omg man you freakin Rock!!! I was able to turn it off! I had to set RPM levels for all of the lights. for some reason all of mine were 0. I just set them at 2k 3k 4k 5k 6k and 6.5k and now they only come on when reaching those RPMs respectively! Wow!!! Thanks a ton bro!!!!:headbang::cheers:
rozay
rozay
2015 PQ 5.0 MT
Glad it helped you out
El_Centenario
5L V8PWR
Apple Valley , CA
David
Thanks for the tip! Will set it up tomorrow :headbang:
Choking_Victim
Arizona
Justin
2018 A10 GT PP
[MENTION=15893]rozay[/MENTION] I tried this exact set-up and mine still require me to touch screen to fire up....do you mind telling me all the setting you have configured? Thanks in advance.:headbonk:
rozay
rozay
2015 PQ 5.0 MT
Just update ngauge with new firmware at Lund support Web and it'll fix it self
