My thoughts on h-pipe with roush axlebacks
clevernickname
BC, Canada
2015 Magnetic Mustang GT, 2016 camaro ss (gfs), 2015 range rover sport, 2013 ford explorer, 2017 WRX
Got my roush AB put on first 1.5 years ago. Put on the h-pipe today and finally the lower rpms are loud enough. And i very much like the tone as well. Not too raspy, kinda deep actually. From 0-3000/4000 rpm its good. Then suddenly around 4000+ its freakn wake the dead loud and SUPER raspy. Like a ripping noise. I don't mind the loudness actually, and I'm probably gonna keep this for at least a year since I just got it, but the tone is a little TOO obnoxious for me. Is there a way with my current setup to mitigate that high rpm rasp?
Or what is another exhaust setup that can be almost as loud without that super raspy/ripping noise.
kluke15
Reno, NV
Kenny
2017 Mustang GTPP
had the same set up with an xpipe instead of the h but i welded in some bottle resonators from vibrant that i got at summit racing. it cuts back the volume just a little bit but does wonders for the tone. so i just welded them to the back of the xpipe and done.
BmacIL
Enginerd
Naperville, IL
2015 Guard GT Base, M/T
At higher rpm the H-pipe basically becomes a straight pipe (very little mixing), which is your ripping sound. An X will have much less of that, much smoother, but will still be raspy. X with some bullet resonators behind it would be good I think.
armykyle1 [HACKED ACCOUNT
Gulf Coast
2018 GTPP premium
I don't understand why don't get that these engines have some rasp to them. More so at higher RPMs. It's pretty much any Dual cam V8. Audi 4.2, BMW 5.0, Jag 3.9, Ford 5.0
Like it was already stated, an X-pipe will help smooth it out up top, but you have ROUSH A/Bs They're about as raspy as it gets.
clevernickname
clevernickname
BC, Canada
I could've sworn people said h-pipe = deeper and x-pipe = raspier. Will bullet resonators work with the h pipe?
Will x pipe + bullet resonators be raspy at low rpm or better too?
66sprint6
Middle TN
2015 Base GT PP
I too welded in a couple vibrant resonators and the rasp on my setup is long gone. I hated the way my exhaust sounded without them and was a tad skeptical that they would work but now I cant tell enough people about it!
Gulf Coast
2018 GTPP premium
The roush are straight through mufflers and create little back pressure, which doesn't allow the h-pipe to be effective at high RPM.
BmacIL
Enginerd
Naperville, IL
Also the H sounds very coarse to me at lower rpm. To each their own.
clevernickname
clevernickname
BC, Canada
Hmm that's a new word I haven't heard when describing exhaust sound. Could you elaborate on what coarse means in this context?
Also why is every exhaust setup I find either raspy or deep. Is there no middle ground?
hinch
uk
Sideways
X's don't have to sound raspy at all it seems alot of it is down to how big the cross over point is. I made an X with a very long (about 9 inch) cut and its not raspy at all if anything it sounds very poppy and bangy especially coming off the throttle.
[ame]
