My Mode ?
TEAsGrabber
BAMA
Todd
2022 Ford Mustang Mach1
I've searched but haven't found anything specific. So, I'm asking here to see if anyone has had my problem. If I toggle to "My Mode" prior to starting it automatically changes the exhaust setting to "Normal." I have tried resetting and saving etc. and actually changed it totally to the "Drag Race" default and saved it as "My Mode." If I toggle to it prior to starting it even changes the "Drag Race" exhaust to "Normal." If I toggle after it's started it doesn't change the exhaust setting. I'm scratching my head....Help! Thanks!
The Spider House
Lancashire
Phil
Ford Mustang Mach 1
☝this.
Its annoying but all you can do is initially set up your "my mode" settings. Once done you can then toggle after the car has started.
One good thing is while you are fannying about toggling through the modes, at least the oil and coolant are doing their thing before you set off.
TEAsGrabber
TEAsGrabber
BAMA
Todd
Hmmmmm.......Everything stays in "My Mode" settings except the exhaust. I just went out and put it in Track Mode prior to starting and it only changed the exhaust to normal.
TEAsGrabber
TEAsGrabber
BAMA
Todd
Thanks ya'll..... It's the first time I've had that display on the dash....I've been driving around all this time in normal exhaust mode.....too funny! 😲
NHMach1
California
Nate
2020 Mustang GT
A trick I just learned is that if you put the shifter is S, Sport mode you can get your my mode in that setting. I prefer the Sport shift and throttle logic over the Sport plus. You won’t have to move the shifter again if you like that mode and make it part of your my mode. For my daily driving I like Sport, sport steering, normal shock, sport exhaust.
