jstump2490
Did I say the car should start the first time without the FOB??? No, I did not. The car needs to be started with the FOB at least the first time in a drive session, but if you start the car and your wife drives it away while the key is in your pocket, you are basically saying they should be hurt because of a slight oversight(on your part I might add) in the chaotic world we live in. Good call! This is just 1 of a million situations that could happen.In your world, I guess you shouldn't need a key to start the car AT ALL, just to unlock the doors, pretty much the same effect...
IDK, IF you start the car and leave the property WITHOUT the fob AND you manage to stall the car in traffic, while taking little Eric/Erica to daycare, sounds like Darwinism at work to me...
There are too many variables and mistakes that can be made when the key is not physically locked in the ignition. Hell, for the sake of argument, if you start a car with a physical key and leave the car running, the car can still be stolen. The car is not going to say "Hey, you are not the owner" and shut off because it has a key in the ignition and is content knowing that. Same with the FOB except it is entirely possible to be forgetful and leave it outside the car. Same situation, same outcome, no car is being shut off once it is turned on intentionally regardless of what key technology is being used. At least with the case of the FOB, once the car is off for 30 seconds, it is not moving, if someone steals your car with the keys in the ignition, they can take it wherever the hell they want.
