Mustang door panels
Cemclo
Clayton
2019 Mustang GT PP1
Does anyone else have any problems with their door panels /handles?
I have a 2019 mustang and within the cars first 6 months I found the door panel started getting very flimsy. There’s a whole lot of movement and it squeaks non stop.
Has anyone tried to beef it up with extra support?
NGOT8R
Adrian
2019 Bullitt
Try popping off the black cover behind the interior handle and pulling up the window switch cover to access the two 10mm bolts. It sounds like they need to be retightened. I just had mine off and can just about guarantee that is the problem you’re having. Note: Be careful removing the window switch panel, so that you don’t break it. On mine, I just pulled up the rear; releasing two clips and that was enough to gain access to the bolt. As for the top panel behind the door handle, there is a cutout in the plastic. Use a pick or piece of a coat hanger bent into an L, insert it into the cutout and pull quickly to release the clip.
Mustang5ohMan
A
2019 Mustang GT PP1
Have not noticed that in mine. I am 5k miles and 6 months ownership on my 2019 I purchased new.
