motor mounts for 1000 HP
dodger789
L.A.
john
2016 gt performance, whipple, stage 2 throttle body, rxt clutch, cf driveshaft, steeda subframe kit, 840 hp axles, X force w/ corsa long tubes and mickeys
can anyone recomend the best motor mounts not the brackets. I destroyed mine at 800 HP figure I should upgrade before I drop in the aluminator...thanks
Prodigal
OKC
2021 Mach 1
Which ones gave up the fight at 800 hp? Factory? I’m liking my steeda adjustable mounts on BMR brackets. I’m not throwing 1000 horses at them however. I went this route for clearance, adjustability and just trying to take the slop out of the driveline.
dodger789
L.A.
john
Yes they where stock. Im looking at the steeda with my stock brackets. Im concernd about drive pitch angle and vibration. Do I want adjustables?
Prodigal
OKC
2021 Mach 1
The adjustables actually allow you to deal with driveline angles and address vibrations if you have any. I went with a 1 piece driveshaft and the motor is at factory height. There’s more clearance which helps with LTH. Those factory mounts are the size and appearance of the largest navel Orange I’ve ever seen.
dodger789
L.A.
john
I have a one piece as well and im going to address drive line angles AFTER I put in the mounts. I have a tremec. What height would you recomend on the steeda spacers
Cory S
Bradford, NH
Cory
2016 Mustang GT Premium
My original engine mounts are still holding perfectly.
