kray
- Oct 6, 2015
- Salt Lake City, Utah
- 2015 GT 2014 Edge 2013 F150
The large hose connects to the bottom of the tank. The smaller hose that lays across the radiator connects to the upper front. The rear connection is for the overflow that routes to the ground. My Mishimoto tank came with a pre bent hose that routed straight down the back of the tank. Route the hose away from moving parts. A lot of times you will get a piece of wire from the wire feed welding process inside the tank. You should be able to,shake it out. I had a piece of wire in a Roush muffler that took me about an hour to finally shake out.
