Radiation Joe
- Feb 8, 2016
- Allentown, PA
- 2017 EcoBoost PP Manual Recaro
I just read the second page of the thread. The conversation went in a good direction regarding engine electronics pulling power. Sorry for going off on a tangent.All of you are barking up the wrong tree.
If you are concerned about failures associated with oil temperature, then the first thing you do is run Redline or an equivalent oil. The "red" zone on your gauges is set for average oil. If you have an oil that performs well at high temperatures, the red zone is less of a concern. If you are buried in the red zone, then you need to find a cooling solution. Fixating on getting values from your data logs is missing the trees for the forest.
