MMR Engine Block Support / Bellhousing Braces for All 5.0 / 5.2 Coyote / Voodoo
Mod Mustang Racing
California
www.modularmotorsportsracing.com
Worlds Fastest & Only 5 second Coyote
MMR's Block / Bellhousing Braces help prevent common cracking of the engine block and or bellhousing on all 5.0 / 5.2 Applications due to vibration and harmonics.
If your reading this, the chance of your block already being cracked is possible! Not to worry, the MMR Block braces will help prevent further damage to the block and transmission. If your block has not started to crack this will help prevent it!
The MMR Braces are a easy bolt on and connect the unsupported lower section of the left and right side of the bellhousing directly to the block, just like the 2020+ GT500.
Dont let this failure ruin your vehicles value due to non matching transmission and engine block #'s - this is cheap and easy insurance!!
Highly recommended for all Street, Drag and Race Applications - even if 100% stock!!
PATENT PENDING
Features:
Easy bolt on (Most can complete in 15-20min, car needs to be raised on jack stands for installation)
Billet Aluminum Construction
Black Anodized for Corrosion Resistance
Hardware Included
Protects your vehicles Value
Order now: https://www.modularmotorsportsracin...h_in_description=1&keyword=Bellhousing+Braces
Racsirx
Concord, CA
2017 GT350
Ford went to install a new replacement motor on my GT350 and the tech noticed it was cracked by the starter area, this is crazy
Mod Mustang Racing
Mod Mustang Racing
California
Unfortunately there are 1000' out there like this, thankfully this product tackles the issue.
dsiggi
White Lake, MI
2019 GT350R
Are you saying that there is a factory part for the 2020 + GT500 that ford did to aliviate the issue?
Mod Mustang Racing
Mod Mustang Racing
California
basically, yes. The GT500 uses the oil pan to support the bottom of the bellhousing. Unfortunately the GT500 oil pan does not connect to the 6 speed transmissions so this is why we manufactured the braces (to essentially do the same thing)
gameovergt
Kevin
Lake Asbury, FL (Jacksonville area).
Kevin
2022 Ford Mustang GT California Special (A10)
Just ordered a set with next day delivery.
Ecoboost1023
Jay
2023 Mustang GT
I have a stock 5.0 2023.
I am interested in this product, however I see many reviews that this requires modifications to the heat shield around the mounting locations ?
Is this true ? Can you share the installation instructions here ?
NGOT8R
Adrian
2019 Bullitt
I didn’t have to modify anything when I installed these on my 2019 Bullitt. They’re very easy to install (3 bolts per brace).
DougS550
Indiana
Doug
I just installed mine. I removed my passenger side pan heat shield and applied DE heat barrier adheasive tape where the heat shield was. The drivers side I cut the rear bottom portion so the brace would fit without self induced stress. I wrapped my LTH with.DE titanium heat wrap. So I don't have much heat in that area anyways. Good luck.
