You'll be fine with either. Give us a shout if you have any questions.Any difference or preference? Same price so I wasn’t sure which to get.
Ordered the McLeod one with the rxt, along with pilot bearing, slave cylinder (ford), arp bolts and stainless braided line. Lethal ftw again!!You'll be fine with either. Give us a shout if you have any questions.
Too many stories of the rst not holding the power or glazing from hard driving. It all depends on your goals and how you drive.RXT eh ? I don't think your gonna like it much. RST woulda been my first choice.
I went with the LPX twin and billet steel flywheel for my whipple setup. It's kevlar material and has a nice feel to the engagement. Plenty of grip, but not too harsh. Only a hint of chatter if you are lugging when you are pulling into the garage for example. The pedal feels like stock. I haven't abused it yet as I'm only 250 miles into the break-in.
My only complaint so far is it seems to start kissing the first disc pretty close to the floor. If on a level surface, the car will start to creep just a bit as you let up on the clutch pedal a few inches. But the meat of the engagement is halfway up or so on the pedal throw. If on an incline, it will not stop the car from rolling backwards, but you can just feel the clutch start to drag a few inches off the floor. @Logan@Lethal is this pretty typical?
That is the exact feeling I have. The LPX is made by McLeod, so very similar to the RXT. I really don't notice it much when taking off normally from a light or stop sign. More so when I'm creeping the car around like backing out of the driveway slowly.granted i have the rxt but have a similar issue and always chalked it up to being the twin disk now curious if its not haha starts to grab then almost has a dead spot for a second then finishes grabbing
Other than that, how do you like the RXT?granted i have the rxt but have a similar issue and always chalked it up to being the twin disk now curious if its not haha starts to grab then almost has a dead spot for a second then finishes grabbing
Totally expected some chatter, all good there. My question on the engagement is when is it normal to feel contact with the first disc? When I start disengaging the clutch, it starts kissing what I assume is the first disc (pressure plate to first disc) an inch or so off the floor. On level ground, it will make the car creep. But as I said, the meat of the engagement is higher up which is great. As long as it doesn't lock me out of high RPMS shifts, I have no concerns. I just thought it was strange to feel very slight drag on one of the clutch discs that close to the floor.TL;DR Twin discs take getting used to but will outperform the transmission's capability. Mcleod twin discs have a very light pedal feel (even our LPXHD is only slightly heavier than stock) with a high engagement that takes getting used to. The benefit of having the LPX series is that even with the high engagement, you can slip it so makes racing easier.
Sorry, my TL;DR wasn't short. lol
That's normal. Same thing on the RXT I had in the GT500Totally expected some chatter, all good there. My question on the engagement is when is it normal to feel contact with the first disc? When I start disengaging the clutch, it starts kissing what I assume is the first disc (pressure plate to first disc) an inch or so off the floor. On level ground, it will make the car creep. But as I said, the meat of the engagement is higher up which is great. As long as it doesn't lock me out of high RPMS shifts, I have no concerns. I just thought it was strange to feel very slight drag on one of the clutch discs that close to the floor.
Hope I'm making sense @Logan@Lethal !
Thanks @Logan@Lethal ! I'm 250 miles into the clutch break-in period. I have serious stop and go hell in Chicagoland. I'm not sure my right foot is going to make it to 500!That's normal. Same thing on the RXT I had in the GT500
