Manual shifter brackets
ABPP2
Alberta Canada
Brandon
2019 mustang GT PP2
I’m looking into both the blowfish racing and the full tilt boogie bracket for my 2019 GT. I’m just wondering what the opinions and experiences have been with either of these. I will be changing the trans fluid at the same time. Wondering about the experience with these bracket with removing the trans weight.
CanadaCalvin88
South Florida
Calvin
2015 Mustang GT
I installed the blowfish on my '15 GT and am very happy with the results. I was getting locked out of 2nd gear at high rpm shifts, but all seems good after the blowfish. I did experience a pretty bad rattle from the reverse lockout collar, but that was fixed by installing the steeda billet aluminum collar.
3onthetree
Long Island, NY.
Frank
2017 GT Man. W/PP
I installed the Blowfish 10k miles ago. It didn't help my 2nd to 3rd nibble, but the shifts feel more direct. The shifter gives a slight vibration, like a top loader, whereas no feedback at all in stock form. I also have the audible vibration from the lock out collar. The instructions describe an adjustment that should help alleviate this, but have not gotten to it.
ModularKid21
‘15 GT
I have the FTBR bracket and it makes the shifts feel more precise as there’s less movement now. I changed the trans fluid prior to the bracket and that helped some. After the install of the bracket, the 1st-2nd nibble I had was gone, unless I’m driving the car in temps below freezing (which is rare) I do have a rather loud buzzing from the reverse lockout collar, so I switched to the Steeda billet one and it actually didn’t change at all. It happens at certain rpm’s and loads so I’ll just deal with it for now
I do also plan on getting a fairly heavy weighted shift knob so I’m wondering if that’ll dampen any of those vibrations. I’ll try and find/link the thread that talks about the FTBR bracket
https://www.mustang6g.com/forums/threads/wow-shifter-bracket.117869/
3onthetree
Long Island, NY.
Frank
2017 GT Man. W/PP
Been 7 months and Just got around to adjusting the Blowfish Bracket. A small angle adjustment to keep it from touching the bottom of the shifter and vibration gone.
2017GBGTPP
Albuquerque, NM
2017 Grabber Blue Premium GTPP w/ Recaros
I have the FTBR, I'm very happy with how locked in place the shifter is now. I was able to get the o-rings in well enough to minimize the rattling, but I might get a new lockout collar eventually. No complaints other than that.
