Make is louder or make it lighter?
Stephen@lethal
2020 Mustang Gt500
Weight savings are def important, and are usually pretty cost effective for the results you get. It just depends on how light you are really wanting to go, but most do a combo of both. Hit me up over at Lethalperformance.com to see what we can do for you!
bluebeastsrt
Oh boy
New Jersey
BigD
Ruby red 2019 GT Premium.
I definitely disagree with the cost effectiveness of weight savings. As primary first mods. Just for the fronts. Light weight brakes $700-1500 dollars. Plus install. Light weight wheels $250 and way up per wheel. K member $1100 and up for a 39 pound weight reduction. Plus cost of install. Light weight battery $300 for a 15 pound savings. $200 for a front and rear crash bar that saves 15 pounds combined. And you have to remove half the car to install. Aluminum drive shaft cost 6-800. But only saves 10 pounds. And they vibrate more than stock. Now taking seats and floor mats out is free. Draining windshield washer fluid is free. Once you get past the free stuff. You can tie up 3 or 4 grand to drop a couple hundred pounds. Or you can get an E85 tune and headers. For less than $1500. Header install is another $500. Its easier to add power.
Stephen@lethal
2020 Mustang Gt500
Oh I agree, as a first mod, its not something I would do alone for sure, but it does become the more cost effective mod at for a bolt on car after a certain point.
3star2nr
Ray
2016 Ford Mustang GT PP
My next step was going for LT headers but I’m wondering 1. What kind of power can I expect 2.how much louder will it be? (Currently have x pipe and borla exhaust). I love the way it sounds now (a little louder would be nice) but my friend has a full corsa setup on a charger and it’s PAINFULLY loud. Was also considering mods to lighten up the car instead.
thoughts?
It's gonna be really fucking loud...
Especially if you have a 3" catback and no cats...
Five_Point_OHHH
Five_Point_OHHH
New York
2016 Mustang GT PP
Yea, loud I'm ok with, but really fucking loud is a concern. My buddy has a charger with full corsa and its fun for about 15 seconds and then you just can't hear anything else. And i'm not trying to get kicked out of my building.
3star2nr
Ray
thoughts?
What size borla exhaust do u have both the stinger and atak come in 3" and 2.5"
I'd imagine the 2.5 wont be too bad. And you have the option of taming it later by running resonators. And worse case scenario a removable silencer
Also do you ever plan on supercharging?
If yes get the 1-7/8
If no get 1-3/4 you will make more power with the smaller primaries on an NA build.
I'd just get the headers installed and tuned then you can worry about taking the noise.
Good luck man
5had0w
Phoenix
2016 GTPP M6
Recently had headers installed.
1. Sound projects further and it’s not painful. It can be for others though. I’ve learned not to care. Also I’ve had experience with/without a tune for LTH. #2 will express the difference.
The aim wasn’t for the loudest cat-back to combine it with to start with (Corsa sport). I’m more the considerate type, and it’s fun. It can easy be controlled with your right foot and yes it can scream when you let loose. I’ve come to enjoy it honestly. It’s a nice option to have.
2. Power has increased for sure. Reference point being 2nd gear, it used to be a fun 100% throttle power gear. Even with a NON LTH tune. Now 3rd is my fun power gear when tuned for LTH. This is for 91 btw. Traction no longer holds in 2nd in any way unless using less than 100% of the pedal.
Weight reduction can be done for sure, it is however usually the most expensive when it comes to cost/benefit. If you wish to veer towards that direction, awesome.
Yes biased but I love to tell people, we all have at least 20 lbs we can lose. Consider starting there? lol. Costs less than 2 piece rotors or the inconvenience of removing any seats. Yet alone anything else.
2morrow
DesignR/DriveR/RiceEatR
NorCal Bay Area
Todd
'16 Mustang GTPP
Valid points and appreciate it, although I'm not planning on dragging the car, plan is to track it
For a track build (Not strip, theres a difference) losing weight is great for performance. You'll handle, brake and be able to change direction better.
However, it gets expensive.
Your thoughts of rear seat delete (mine is coming out too), Lightweight buckets (Check out the Sparco QRT series, Amazing stuff with great value) are all good ideas.
I'm adding a lightweight 4 point roll cage so I'm adding weight back in. If you got dollars to spend check out the antigravity batteries but don't waste your time or
money routing it to the rear as adding the cables add a lot of weight. Lightweight rotors are great for this too. I'm sure you do this already but take out all the crap
in your car/trunk (pump, center console contents, etc.). A friend of mine even unbolts the shotgun side seat. Long story short, save your money.
I did both, added power and lost weight and the car is a BLAST at the track.
To your comments about volume, one thing to think about is noise level at tracks. Some tracks have noise restrictions and I've seen people get booted which really
sux when all your friends are having fun and you're on your way home.
I'm assuming your home track is Mid Ohio? Got any footage yet?
Be safe out there.
