Mach 1 Resonator Delete Different than 18-21GT?
Mazman
Sweden
2018 PP1 Mustang GT
Here you go the distance is set with the rear cuts to the tail pipe. Just remove the resonator & replace it with the H pipe.
first step
and
loosen clamps remove resonator
This step AE valve plugs can get damaged.
Install the H pipe in the front clamps first, sung.
Then exhaust pipe to H pipe.
Use same care connecting & clamping .
Check O'Reilly
Do all the res-deletes have the same lengths?
Thinking if that measurement is for a specific delete.
Steeda only says this in their manual
and yes the provided clamps do not hold the tips aligned for long
Rapid Red
Woodstock GA
Greg
Thanks Greg! This is great info.
These measurements aren't there on the Steeda H-pipe instructions. Hopefully they are all the same. where did these instructions come from?
The install instructions, sourced from Roush. Installed the X pipe, the H & X are the same size.
Steeda is a very respectable & accurate parts resource, parts fit as they should.
Steeda has been my resource for all suspension upgrades, they sell what they race .... FYI
Roush web site, find H pipe, bottom of page, down load full instruction sheet. It also list the torque values of the clamps.
But, no mention of the AE valve got-cha, not a slam just a fact .
Cheers
Mazman
Sweden
2018 PP1 Mustang GT
Cheers
Was thinking if the length of the res deletes from Steeda and Roush are not the same and if someone goes with Steeda and cuts with the measurements from Roush and ....
As long as the mufflers are supported while cutting I see no risk of damaging the parts related to the active exhaust.
ChitownStang
ChitownStang
Chicago, North Shore
2021 Mach 1
Cheers
I guess when I do it, I'll hold it up to were I think the front pipes would be in the front clamps and mark the cuts, then measure to see if the Roush is the same and go from there.
I would imagine these are all similar products with people stamping their name on them.
Rapid Red
Woodstock GA
Greg
This will answer the question, H pipe end too end 32 in, the 5.5 measurement will set the clearance.
If H pipe is longer or shorter, adjust the 5.5'' +/- measruement , not difficult.
To the left, 5.5" stick out, (Mustang speak poke out ..)
32" mark is at front of the part.
ChitownStang
ChitownStang
2021 Mach 1
This is great info. Thank you for doing this!
Steeda h-pipe says it’s 32” on website but I’ll confirm when I receive it in the next day or so. If so then 5.5” off res to cut would be same. Cool!
Steeda says it comes with these butt clamps but maybe the link you sent are better ones?
People have mentioned hooker torca header clamps but seems like 2.5” is all I’m finding.. you sure in the 2.25” for the clamps?
WD Pro
United Kingdom
Lime GT
If you need an answer sooner / before yours arrives, I have the new / shorter Steeda H sat in the garage awaiting fitment :like:
WD :like:
ChitownStang
ChitownStang
2021 Mach 1
WD :like:
Cool! Can you verify the clamp is 2.25"
I want to get better ones as a precaution
WD Pro
United Kingdom
Lime GT
Looks like 2.5” over the larger (rear) end where the non OE clamps are fitted :
WD :like:
Rapid Red
Woodstock GA
Greg
No, just grabbed a quick example what I thought ice445 was referring to. Sometimes a picture is worth a thousand words...
Measurement for the clamp is the outside of the H pipe, tail slips inside of it.
So must wait grasshopper LOL
Always one more trip to store ..
ChitownStang
ChitownStang
2021 Mach 1
WD :like:
Cool, then I’m going to order the Hooker ones to match the own front clamps.
$22
Thanks for the measurements
jpilone
Vermond
2016 GT350
ChitownStang
ChitownStang
2021 Mach 1
Wouldn't you know it, the Hooker 41172HKR Butt clamp is out everywhere until 5/20
Cmon man!
