Mach 1 Race Mode - Throttle Response?
2021 Mach 1
England
www.youtube.com
Mustang Mach 1
‘Traction control’ is the ‘simple system’ that controls wheel spin.
‘Advance trac‘ is the more complex system that takes into account yaw and steering input etc etc. It’s the one that wants to keep you going in the direction that the front wheels are pointing.
I think track mode turns off traction control but just subdues advance trac.
You can then hold the mode toggle and it will give you a second message to tell you advance trac is also off.
Only it’s not off fully, you need to pull the dyno plug (near the air box on the inner wing /fender) to completely disable the nannies :like:
WD :like:
Thanks, good to know. I am planning some drive-by and burnout videos for the YouTube Channel.
WD Pro
United Kingdom
Lime GT
Be careful, I think the dyno plug can also be called the crowd control plug or the youtube plug ... lol
WD :like:
2021 Mach 1
England
www.youtube.com
Mustang Mach 1
What about traction control? Is it Normal>Sport>Sport+>Track? So Track mode is the easiest to light up the rear tyres?
I can confirm that Track mode is easier for burnouts than Sport+
Mach1Yorky
Yorkshire
Antony
2020 Mustang Bullitt
On my previous Bullitt, I had opportunity to practise donuts pre new tyres being fitted. I found track mode with full traction / stability was best and in fact very easy to control.
With Mach 1 Track mode, with 1:1 throttle pedal, I feel it would be easier in Sport Plus and traction off as having an sharper throttle pedal makes it much easier to modulate throttle when control slide.
Mach1Yorky
Yorkshire
Antony
I meant full traction / stability off !!
