Lund Tune on auto 17 GT
Laztug
Wanna run dyno slips bro?
COTUS
Calling out OKC #1 spot after axle back install.
How hard is the torque converter to install? Should I just go to a shop or is it fairly simple.
Tune the car when you are ready to lose the warranty.
I have a Lund tune on my 15 GT A6 and am loving it. It is a little jerky going into second at low speeds, is that normal? Also, do you think you could clarify a bit if the tune changes the behavior of the car between having the shifter in D vs S? When I have the shifter in S and use the paddles, I noticed that the car holds every gear now. Will it still shift on its own before hitting the rev limiter? (Which is at 7700 now?)
My car shifts hard at high rpms and smooth while driving around town. *not lund tuned*
Once you hit the paddle in "S" mode the car will NOT shift for you.
Bluemustang
2015 Mustang Base GT
Yes - as stated above, once in S and you hit that paddle - it will not shift up on its own. It will shift down eventually as you are slowing to a stop.
beefcake
Bethel
2018 Ford Mustang
