Lund tune idle question
Bluemustang
2015 Mustang Base GT
Does anyone know why Lund sets the idle at 740 RPM? Just wondering why it is higher than the stock idle.
Kahboom
Kahboom
Cathedral City, CA
2015 Mustang GTPP, Recaros/2014 Explorer Sport 4X4
Is it a flex fuel tune?
Jay-rod427
Kansas
2016 GT C/S
No clue why, but they do. Some have said they have requested it lower, but won't happen. Maybe slightly higher idle to keep it smooth with a little more aggressive base idle cam timing?
Kahboom
Kahboom
Cathedral City, CA
My flex fuel tune was the same, had to get it dialed in a bit before they would lower it. Now its 650-675rpm at idle. While deceling the rpm would dip past the target idle and the car would stall or die completely. So had to do several data logs before it was good at idle for my flex fuel tune while the regular octane tune did not do this. Maybe Lund is the same, not sure.
wireeater
Virginia
wheelwell.com
Rich
Shadow Black 2025 Mustang DH HP
If it's flex tune it could be for cold starting because E85. e85 is hard to start when it's cold out. E85 also takes longer to burn so maybe adding additional RPM helps with that. Honestly just email and ask Lund, i'm sure they will give you the correct answer.
Terminator2
Spring Hill Florida
David
2016 Mustang GT Premium
This. I added 25% more fuel to my cranking fuel and mine still takes a little longer to cold start on E-85 vs 93. I also have my idle at 750 I like it better at 750 honestly.
