Lund Flex Fuel AFR
venumous
venumous
PA
16' Procharged GT
The lower price in fuel evens out for the shitty mpg dosnt it?
30% more fuel used with E85. Clearly you need the same difference in 93 vs e85 price to break even. Shouldn't be running E85 if MPG is something even remotely in your mind.
16s550
Bay area
2016 GT M6 performance pack, whipple charged
Not really. Just trying to get a ball park on how much I'll spend on fuel. I normally spend about 40 to 50 a week on fuel depending how I drive and how much of coarse. So I should expect to still run about 2 tanks a week? Vs 1.5 tanks that I use now? My bad for all the questions
venumous
venumous
PA
16' Procharged GT
Yeah, 30% more fuel would come out to a little more than 2 tanks if your at 1.5 now if your foot activity stays the same as it is when you're on 93. I know when I ran e85 on my STI I tended to drive it harder (but e85 made one hell of a difference on that car Vs the NA Coyote). No problem, lots to know.
16s550
Bay area
Well from pmas cai, Lund ff tune, I'm hoping to gain around 25rwhp. Already have Borla sport catback. I'd be happy with close to 435-450 to the wheels. I won't be able to afford forced induction for awhile. Atleast seems that way for now. Gonna add bbk long tubes because getting a killer deal but gonna install those maybe next month or so.
Todd15Fastback
Atlanta, GA
Todd
2015 Mustang GT PP Fastback
With your mods and running e85, you should end up around 420rwhp SAE with CAI and FF tune.
Niz55
Us
17 GT350
What would you think my house will be @Todd15Fastback ?
FF lund tune
JLT
Corsa Extreme
Gt350 manifold with stock tb
47lbs injectors
Shifting at 7800
BTW, do you recommend running 0w-40 castrol with my setup?
Niz55
Us
17 GT350
10-10.4 afr at idle, 8ish WOT. Just watch lambda 1 and 2. They should be around 1.0 at idle and .85 WOT.
@RubyRedBoost
very confused about the whole e85 AFR. Mine is at 9-9.5 at wot. Am i running lean? I do have 47lbs injectors and gt350 manny shifting at 7800RPM. car pulls very hard.
Todd15Fastback
Atlanta, GA
Todd
FF lund tune
JLT
Corsa Extreme
47lbs injectors
Shifting at 7800
I would assume you will put down 435-445RWHP (On E85) range based on your mods and what others are putting down with the same mods that have shared their #'s. We all know each dyno reads differently, etc. but just sharing what I have seen thus far.
The oil question. I guess it depends on how you drive your car. If you are hard on it, I see no issues running a the weight you have shared. I have been runnning 0W-40 for over 12 months and 3 full oil changes with zero issues. I use Pennzoil Ultra Platinum but will be switching to Amsoil my next change since I just started running E85. This is due to all the oil sample testing that has come back with Amsoil and E85.
UPRSteve
Lake Worth, FL
www.uprproducts.com
15 GT
lund tunes for lambda, a/f will very based on different stoichs of fuel.
unless something is way off in the mechanics of the car ,especially n/a, the car will be be the exact stoich lund wants
THIS!
