racer24crm
- Oct 29, 2014
- Philadelphia
- Chase
- 2015 Ruby Red GT
Ok, so long story short, low voltage warning came up on the dashboard on my way to work. Started car when leaving and it was fine at first, then I get a more serious looking warning to "check charging system immediately". The voltage was down to around 9 volts. I was close to home luckily.
Anyway,I park it in the garage and the negative battery terminal is very corroded. I clean it up and hook the battery back up. Warnings go away, voltage returns to the normal 14.1 to 14.3 volts that I've always had.
I've been driving for the past couple days with no issues but tonight on the way home the low voltage warning came back and the voltage was 10.8.
The car has 55k miles and the battery is 9 months old. Do you think it's an alternator? Car runs fine once it is started which makes me think it's the battery or cables.
What do you guys think?
Thanks.
Thanks.
