Low Fuel Pressure (WOT ONLY)
a10jay
Richmond, CA
2019 Mustang GT (PP1)
2019 Mustang GT (14K Miles)
CAI, Headers, E85, Lund Tune
Stock Injectors
Stock Manifold
DW400 Fuel Pump
Stock fuel pump was replaced due to failing. Replaced it with a DW400 and ran into low fuel pressure issues at WOT. Assuming it was a faulty fuel pump, I replaced it AGAIN and problem still persists.
Replaced the fuel pump 2x, fuel lines to the fuel pump outlets 2x, and fuel pump driver module. Inspected and checked the whole fuel pump assembly/hat for any leaks, cracks, pinched lines, and ect… countless times. All the ground wires, fuses, and relays are all good. All stock fuel injectors checked out to be good.
Datalog Details:
Fuel pressure drops from 80 to 70 at 5400 rpm’s. Drops to mid 60s at 6000rpms. Drops to 54 at 6400rpms. Drop to 45 at 7000 rpm’s and then 43 at 7300 RPMS. Code P008A. Voltage is 13.2V-13.5V.
Anyone have any ideas or solutions? I’ve already discussed my problem with Lund and two mechanics that work on LS/FORD but neither one of us can find a solution to the problem.
mangosmoothie
Flagstaff
Casey
2019 Boolet
my only guess from here would be an issue with wiring to the fpdm or to the pump. Checking voltage at the FPDM is easy enough. Not sure how you'd check pump voltage at WOT though.
I would probably start there to rule that out
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
'17 S550
Try a different sock ?
KingKona
Virginia
Shlomo
2019 GT
Put a stock fuel pump in.
KingKona
Virginia
Shlomo
2019 GT
How old is your battery?
a10jay
a10jay
Richmond, CA
Fuel pump driver module was replaced and voltage at the FPDM and pump are good.
a10jay
a10jay
Richmond, CA
Deatschwerks already supplies the correct sock for the specified fuel pump, DW400 w/ 1047 installation kit. It’s a perfect fit. I’ve even tried raising the fuel pump a little so that the sock isn’t possibly causing any restriction when sitting flat at the very bottom of the hat.
a10jay
a10jay
Richmond, CA
Based off the datalogs my voltage is as good as ice cream on a hot summer day. The battery is perfectly fine. I couldn’t tell you how old it is I just know it’s doing it’s job.
Andy13186
Have you tried using any fuel system cleaning product or seafoam? Weird issue, will like to know the resolution.
WildHorse
N/A or GO HOME
'17 S550
Then it's a tune issue. Do they use this data ?
a10jay
a10jay
Richmond, CA
Fuel injectors were tested and had no faults whatsoever during the process. Lund is saying it has nothing to do with Fuel Injectors. I’ve heard of 3-4 other people with similar issues. They either ignored it, blamed the tune, or still trying to find a solution.
a10jay
a10jay
Richmond, CA
Tuner is Lund. They actually have someone else dealing with the same problem and we are all trying to troubleshoot it. Being that they have tuned thousands of cars NA/Boosted equipped with DW400 pumps and have had no issues, I have a hard time believing it’s the tune.
KingKona
Virginia
Shlomo
2019 GT
I'd take it somewhere where the really test it. Load test it. This sounds like an electrical issue, and these cars are extremely sensitive to batteries being the slightest bit out of spec.
Soulja4187
Greenacres, FL
David
2021 Mustang GT Premium & 2022 Audi A5 S-Line
Toby had the same issue with the DW400, his buddy end up installing his E85 fuel pump and all issues went away. Check out this Video and fast forward to 30:20, he will talk about how the DW400 was giving him low fuel pressure at WOT
